EtherOAM.RxPDUUnk
Description
Ethernet OAM received an unknown or unrecognized PDU. This should never occur, but if it does, we simply drop the PDU. Receiving a large number of these messages is indicative of a problem at the lower layers.
Remedy
Check that the peer is running a compatible version of Ethernet OAM.
Severity
Warning
Message Text
Unknown PDU received on port %port%. %typeInfo%
Message Parameters
Name Type
port SlotPort
typeInfo uInt
Applicable Platforms
